Info For An Ademco Accord
PeterM
Hi,
New to the forum so hoping you can help.
Bought a house recently with an Accord fitted, all working well and recession strapped so don't particularly want to change it! But with a new cat in the household I need to fit some pet friendly PIRs. My question is how do I understand what specification i.e voltage and frequency the control box is/needs to specify the sensors? Looked at the paperwork I have but see nothing apart from it needs Normally Closed units.
Many thanks,
Peter
any standard pet sensor should work after being set up, the one thing youll need is the engineers code but this site cannot give the default code out to you, the voltage that panel works on is 12v dc, youll need the engineers code to be able to replace the pir, otherwise the tamper will keep activating, you may also need the engineers manual aswell it may make things easier to understand, as for any codes, or engineers manuals this site cannot give them to you sorry, but if you are not sure what to do with the system take a look at the companies listed under each police force area and im sure someone will be able to help install those detectors if you decide to go that route
07475071344
Cats are a pain in the botty.
Leap about everywhere.
Even a good "Pet Detector" can struggle.
Aim them away fron stairs and "Cat comfy places" then you`ll have less of a chance of a false alarm.
To be honest you need a "pro" or be very dilligent in the set up of the detector.
Go for a Quad or a DT, with a cat a DT is better.
detectors are 12vs yes they are closed circuits
adi gardeners do agood range of pet smart detectors.
beware if your system is not setup for customer reset you will cause a tamper
fault ? you will need a engineer reset code
to stop pet false alarms programe detectors for double knock
Pardon?
Double knock wont stop that..
An animal isnt going to walk thru 2 detection zones then stop.
Chuck the fekker out if its a cat.
Eats next door anyway, kin hate cats.
Now a soppy basket of a dog dirrerent story!
Pardon?
if the animal is restricted to one area theres not much chance the system will go into alarm?
Depends, cats are a pain.
Leap eveywhere.
