Driller Posted January 19, 2011 Share Posted January 19, 2011 Is this something you guys do much with vandal domes? If so is there a prefered way, swan bracket affair or direct mounting? I've looked for a solution for the SVD4600 and haven't found anything other than a pendulum pole mount which isn't much use. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/30726-pole-mounting-an-external-dome/ Share on other sites More sharing options...
arfur mo Posted January 19, 2011 Share Posted January 19, 2011 but sparse on the info, how accessable will it be to a villian with a scaffold pole or laddet to whack it with? i.e. depends on loction and purpose as to whats sutable, if you feel it's likely to be'attacked' then a second camera is needed so they view the area beneath each other. Arfur If you think education is difficult, try being stupid!!!! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/30726-pole-mounting-an-external-dome/#findComment-266914 Share on other sites More sharing options...
Alpat Systems Posted January 19, 2011 Share Posted January 19, 2011 Is this something you guys do much with vandal domes? If so is there a prefered way, swan bracket affair or direct mounting? I've looked for a solution for the SVD4600 and haven't found anything other than a pendulum pole mount which isn't much use. We've mounted Samsung static domes to altron poles/towers before. If you use the STB-275VW bracket (fits the SVD-4600)together with altron clamp on leg brackets, or you can adapt the telemetry receiver brackets. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/30726-pole-mounting-an-external-dome/#findComment-266916 Share on other sites More sharing options...
cmss Posted January 21, 2011 Share Posted January 21, 2011 have a look on dedicated micros site Link to comment https://www.thesecurityinstaller.co.uk/community/topic/30726-pole-mounting-an-external-dome/#findComment-267339 Share on other sites More sharing options...
Driller Posted January 22, 2011 Author Share Posted January 22, 2011 Arfur, it would be in a position covered by another camera so not a problem. In fact my emphasis shouldn't have been on the "vandal" part at all, my mistake, I just need to mount an external dome on a pole to get it up high enough to look along the other side of a wall. AS I have some other SVDs on STB275s already and I think I have an stb225 lying around somewhere-that was exactly the knd of solution I was after. I'll check out Dm also, thanks. ETA I reckon I'll get me to the local scrap merchant, grab a bit of ally and knock up something like this myself Mr Happy will be delighted Link to comment https://www.thesecurityinstaller.co.uk/community/topic/30726-pole-mounting-an-external-dome/#findComment-267476 Share on other sites More sharing options...
