Cat 5
danlad1980
Cat5e UTP Resistance is 0.938ohm per metre per core (depending on manufacturer).
Maximum cable voltage is 50Vdc/30Vac
0.938ohm * 50 metres * 2 (there and back)
93.8ohm
93.8ohm * 0.5A
46.9
46.9 / 12 Vdc
3.908
46.9/ 50 Vdc
0.938
3.9Vdc dropped @ 12 Vdc
0.9Vdc dropped @ 50 Vdc
I think I worked that out right!?
So James was right! 4-6volts
Maybe he could add it to the SIA Calculator?
93.8ohm
93.8ohm * 0.5A
46.9
46.9 / 12 Vdc
3.908
46.9/ 50 Vdc
0.938
Why there and back??
Because the electrons run down the positive rail through the device and then back up the negative rail
That would be total cable volts drop. OP was concerned about V drop at load - 50metres. Also said using a pair each side.
return current
have been advised before that its more benificial to double up the neg than the pos due to the return trip
odd because you would naturally assume to make the pos bigger!
colour cams with them little maplin's caravan solar panels work a treat, being colour cams there is no need to power them at night.
.........i'll get me coat
On the iP camera course, they mentioned cabling based on maximum legnth allowed (305 feet plug to plug).
the powered ports on the switches were 48 volts DC, I think @ 100 MA. for that distance. So could run a later low power ip camera (without extra power insertion).
If you can't get power at the camera end, say you took the pcb from a 1amp PSU to the camera end, by feeding it 30 bolts dc down the cat5e the psu board drops and stablises it to 13.6, would that be any better than doubling cores?
Arfur
