arfur mo Posted January 29, 2011 Author Posted January 29, 2011 why do you not know for sure if the door is used for ee? Print company, the site was being 'populated' with all sorts of kit when i was there. They plan to work 6 days 24 hour, but can't be sure of the work. If they do they might use the door as workers entrance, and leave office alarmed or the might not - why afaik I'm not certain either way, because rhey are not themselves. Arfur Weld it shut then !!! Problem solved. Like I can dictate this? Arfur If you think education is difficult, try being stupid!!!!
james.wilson Posted January 29, 2011 Posted January 29, 2011 yes if its not an entry door and its only g2 then you can get away without one. Id still use an active beam to be sure securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
arfur mo Posted January 30, 2011 Author Posted January 30, 2011 yes if its not an entry door and its only g2 then you can get away without one. Id still use an active beam to be sure Many thanks James, if i get the order i'll see how they want to 'play' it. likely if all go's to their plan the place will only close Sundays and bank holidays. that means the call out's will likely be at those times. even if they damage anything during the week, tampers tripped, i find many clients don't always call you until they can't use it - then its panic stations . Arfur If you think education is difficult, try being stupid!!!!
