Diy Alarm Panel
IPAlarms
OMG they look tat with the blue legend on the front, I assume they run "zeta" heads rather anything else ?
yes thats the one!took over a few of them.i believe you can put appolo proticol on them.
but these have zeta!such beautifull kit.lol
I hate twinflex. I really rate Advanced and Appllo gear. How odd!
Never had serious problems with either tho.
The worst bit about twinflex is the smoke bases. The number of earth faults from crushing the cables into bases. Apprentices!
id agree the current heads are (begins with s and ends with hit) but they are changing to the same design as those on the addressable stuff. This should already be done now and i am annoyed it isnt, but my only real gripe is the fact you cant use the solo poles on them. As you wouldnt fit them that high it isnt a problem and we only use them at normal heights. To be fair the sita is so cost effective there is little need to use the twinflex, but i dont like the sita panel, so stick with the duonet and quadnet.
why not just buy cel ?
I assume this kit can only work out cheaper if you buy the "zeta" heads ?
