Veritas Prob
connor2425
dont suppose it has a dd243 option? and its looking for a prox to disarm?
If it's a Veritas 8 or R8 it's only Grade 1.
So no DD243, No Confirmed, 10 event log, we are talking very basic.
If it's a Plus or Excel it's Grade 2 so more featues but DD243 is off as default.
The Engineers code is the User code and the User code is the Engineers, that's the only way the engineers will switch off the system.
You have mixed up the codes, put in what you think is the engineer code, press prog, now enter 51, bet it doesnt do anything.
It is easily done because the default user code is dcba and the default engineer code is abcd, ie the user code is the reverse of what we usually expect
thats one of the reasons we sell a lot more accenta's than veritas's.
looking at the manual i cant see an option to prevent pin on entry. Im wondering if its on single key set (ie easy set) and the code is wrong. Thats why you can arm and not disarm.
i pointed this out earlier.one key setting but..
op said engineer code silences alarm.hense the posts saying that the codes are wrong way round.
hopefully thel post back and let us know what happens
QFA The best way to check if in engineers IMO.
missed that id say your spot on, ie eng code and user code mixed up.
