Vesda Laser Compact
connor2425
Anyone had any dealings with these? had my first install today with it but didnt install the normal way.
I had a large void (6m high) of which I had to I had to run the tubing just above the ceiling then at 9 points run a tube up to the roof apex with a inspection holes at the top of each tube. Would this be the correct way to install this system for this type of coverage?
Hope this makes sense!!
Thanks
Thanks
Hi Connor
Hope this is of some help - Pete
vlc_uk.doc
Peter Robinson
Freelance
M:07889038650
Thanks
Not 100% that this would work - when you say you ran a tube up from the main point at 9 intervals was this capillary tubing or did you use T's and the aspirating pipe?
It's a horizontal pipe with a vertical pipe from a t piece going up to high level with the inspection hole at the top.
So it will bring the air in from high level around the low level piping back to the vesda
The sampling port if you are protecting horizontally (ie - along a ceiling) should be facing downwards as per Xtralis design guide and T's should generally be avoided unless for branches off main pipe (giving a fork shape layout) or for capillary tubing.
Yes its a folk shape layout facing upwards with the holes at the top to drag the air from the top of the ceiling, the ceiling is totally unaacessable so ive run the pipe up strutts, this is prob the only way to cover it, so hard to explain!
thanks for the help
The hole at the top is a bad idea because of **** dropping into the aspirating pipe - I'd hae put a 90 deg. bend on it with a short length of pipe and a sampling port looking down into the void.
Did you check the design on Aspire to see if it'll work okay?
I recieved the design off the company I installed it for, the hole is on the side of the tube with a end cap on the top.
Would you say this design was ok then?
It's the first time ive used this so just wanted to check the design was correct, good stuff tho
This method of vertical install is usual in lift shafts etc, or where stratification can occur in atrium but I suppose there's no reason why not,providing one of the end ones are installed within 500mm of the wall.
