Borrow A Texecom Usb-Com?
looops
I know they are only £30ish but for single shot use, wondered if anyone has one knocking around their toolbox? I use a (ComIP module for Wintex etc).
Paul.
Do you want to update panel firmware or ipcom firmware, for panel you need a flash upgrade kit and a usbcom or pccom, for ipcom its done over the network
I have the panel's firmware, sent by Texecom. You can upgrade the COM IP firmware? That might fix the crashing problem I have with it. How's it done and do I ask Texecom for that firmware too?
Thanks
You can change the webpages in the ipcom
That sounds cool. Can I blag some documentation somewhere?
Edit. Found the Examples.html webpages, what's the URL for the functional pages?
