G2-20
Guest newbie dave
Guest newbie dave
Changed the 2 batteries on a smoke detector after panel showing low battery last week on a Galaxy G2-20 with RF portal but it still shows the same a week later. The new batteries are the correct 3 volt lithium ones, am I missing something?
Also if I need to delete a device off the portal do I remove the serial number in the zone programming and program it 18-spare or is there a procedure I need to follow?
cheers
Dave
Guest newbie dave
after changing the bats did you send any signals from the unit?
But yes once you delete the serial number thats it.
Tried testing it and the panel goes into alarm but still showing low battery. Tried new batteries again just in case but still the same so looks like a dodge detector. cheers anyway.
51, 17, ent, try that in-case its just logged a fault that wont clear. This wont default it btw. I presume you have eng code......
