Ts700 - Need To Replace The Battery
schultzm
I have a TS700 Panel but I have just started to receive an "lb" alarm which means the battery is in need of replacement.
I know the Engineer Code but I don't know the keypad sequence to get to Engineer on Site so that I can remove the cover to access the battery.
My 10 year old ahnd written instructions are;
1. Enter the engineers code - E1 on display
2. Press ENT - E2 on display
3. Press 1 - 01-H on display
4. ?????
5. Press ESC - Engineer on site
If someone can tell me what the correct steps are I would appreciate it.
On a TS700
Lb = Low battery voltage
BF = Battery Fault
Both can indicate a faulty battery, but occasionally could be a fault with the panel charging voltage.
Please Note:- Mains Voltages are present inside the panel and on the PCB!
If you are not confident in replacing your battery, seek a professional.
1. Enter the engineers code - "E1"
2. Replace Panel Battery for correct/same type (check polarity)
3. Replace Lid
4. Press ESC - "ENG ON SITE"
5. Enter User Code "Func"
6. Press ESC (within 5 seconds)
7. "OPEN"
Alternatively this can also be done without entering engineer mode.
This way pressing the wrong buttons will not alter programming.
1. Remove lid *Internal sounder sounds*
2. Enter User Code "Lt"
3. Replace Panel Battery for correct/same type (check polarity)
4. Replace Lid
6. Press Esc (within 5 seconds)
7. "OPEN"
