Hard Wiring Alarm System
Vick
I have wired a alarm system at my home. Can I get the advice on using staples to attached the wires. Will I get a false alarm if the wire has a staple in it?
Just pull the staple out and make sure you don't have any shorts on the cable
Hey Ho, Lets Go
Alarm wiring can be installed using special round cable staples with a special gun.
Normal staples will potentially damage the cable.
If you have stapled through a cable this could cause a false alarm, due to damaging the insulation or the conductor.
The cable would need checking/repairing and then testing.
If you know were a cable is damaged this is helpful as generally the hardest/longest part is finding the cable damage.
