Pyronix Paragon Plus Alarm
Guest casamia
Guest casamia
I have a Paragon Plus alarm and want to omit one of the zones, of which, according to the manual, there are 6.
I want to omit zone 6 and the manual says I should enter shift then 0 then the zone number (6) then shift again. If I do this nothing at all happens. It seems that the only option I have is for a full set
Any Ideas?
Have you tried to enter your user code first?
The panel has 3 part sets, but they need to be programmed by the installer..
Guest casamia
19230[/snapback]
I think that does the trick - should have thought of that really but would have been easier if they had put it in the manual
