dsazzer123 Posted March 13, 2011 Posted March 13, 2011 Hi guys, On the visonic complete is it easy to set up the phone feature to dial the four numbers allowed in turn upon alarm activation?and what on the programming side needs doing? Also what is the easiest way to test? Thanks for any feed back..
sixwheeledbeast Posted March 13, 2011 Posted March 13, 2011 Hi guys, On the visonic complete is it easy to set up the phone feature to dial the four numbers allowed in turn upon alarm activation?and what on the programming side needs doing? Also what is the easiest way to test? Thanks for any feed back.. The panel comes with a quick start guide, it's all there. Report to Private set to "all -op/cl" Set the numbers in the user menu Easiest way to test is set the alarm off or open a tamper lid.
