Thorn System 1700
Working with an old conventional thorn system 1700, Cant remeber what the end of line values for sounder and zone circuits are. Anyone able to enlighten me?
Should have a manual for it somewhere gathering dust - will try to check it out later.
Allen
is measuring a correctly terminated circuit too easy ?
  On 15/03/2011 at 18:43, myristate said:
How is that going to tell me? since nothing is fitted
He means measure an existing circuit, your post made out you were working on an existing system.
  On 16/03/2011 at 00:35, kfpel said:
Sounder circuits 22k Ohm
Zone circuits 4k7 Ohm
Regards,
Kieron
Hi Kieron glad to see you posting on here.Are you on here most evenings or just now and then? Pete
Peter Robinson
Freelance
M:07889038650
