Gardner Zone Attributes
Can anyone clarify what the follwing Zone Attributes actually DO on a GARDNER 595 panel
TEST
PT-1
PT-2
"I assumed PT-1 and PT-2 were for assigning a zone part set but may be wrong here as there is no PT-3"
Clnr
"Assume this assigns zones to CLeaner coce"
Ch1
Ch2
Walk
Sec
Per
To help me further and reduce the silly postings can anyone get me a decent installation manual from
http://www.riscogroup.co.uk/Products.aspx?subcatid=84&id=17&funid=2
or anywhere else for that matter
Ok After some research I think I have this nearly all figured out
PT-1 and PT-2 assign zones for Part Sets
Clnr assigns zones to Cleaner areas
CH1 and CH2 relate to Chime tones
Walk includes zones to be used on a walk test
Sec is a Secondary Zone
Per is a Perimeter Zone
So the only one I am not sure about is Test so noe theres only 1 question to answer!!!!!!!!!
Walk is "forced walk test", any zones with this attribute must be walk tested before the system will start to set.
Originally said by Charles Babbage
On two occasions I have been asked [by members of Parliament], 'Pray, Mr. Babbage, if you put into the machine wrong figures, will the right answers come out?' I am not able rightly to apprehend the kind of confusion of ideas that could provoke such a question.
