djr69uk Posted March 18, 2011 Posted March 18, 2011 Hi there I've got a Gardtec 593 with contour LCD (7 segment) keypad and it doesn't get used as often as it should due to the keypad entry having become a chore! So I've done some reading and realised it will allow me to use remote keyfobs to active/deactivate the system as it is ACE compatible. However, I'm struggling to find the fobs online. Could some kind person please point me in the right direction to reasonable priced fobs for this system? Called one security company and they want 45 + VAT. Was hoping I could get them cheaper as I'll need at least two. I suppose the other option is to upgrade the keypad to a newer system... perhaps a G-Tag compatible system as the tags are less than 3 squids from RS components! Is it possible to do that, possibly by just upgrading the keypad with something like this? http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=4931144 Claims to be for the 593, but would at be as simple as just replacing and re-programming the keypad? Thanks in advance
Wooly-bobs Posted March 19, 2011 Posted March 19, 2011 ACE is long gone, G-TAG is a differentg keypad. Nobody will supply a G-TAG RKP, fit and program tags for £45 I'm also a bit confused as to what RKP you have, LCD 7 segment? Its usually one or the other.
Cubit Posted March 19, 2011 Posted March 19, 2011 ACE is long gone, G-TAG is a differentg keypad. Nobody will supply a G-TAG RKP, fit and program tags for £45 I'm also a bit confused as to what RKP you have, LCD 7 segment? Its usually one or the other. I read it as £45 for the fobs.
djr69uk Posted March 19, 2011 Author Posted March 19, 2011 I read it as £45 for the fobs. Hi, yes that is correct. I just want to know if I can buy cheap ACE fobs from somewhere? If not then, can I get a G-Tag enabled keypad to work with the 593? The one on the RS components link suggests it works with the 593 but I'm not convinced! Many thanks
PeterJames Posted March 19, 2011 Posted March 19, 2011 Hi, yes that is correct. I just want to know if I can buy cheap ACE fobs from somewhere? If not then, can I get a G-Tag enabled keypad to work with the 593? The one on the RS components link suggests it works with the 593 but I'm not convinced! Many thanks I dont think you will get cheap ACE fobs now unless someone has some in stock. £45 seems a little strong I think ours were between £25-£30 +vat (They are a bit like car alarm fobs have a button on them and a battery) the keypads are infra red readers you may find an infra red txer that will work. Im going into the office shortly to pick up some stock Ill have a look to see if we have any left and Ill check the price out. I am fairly sure they are no longer made. Pete
Wooly-bobs Posted March 19, 2011 Posted March 19, 2011 Deff not made anymore, i have a few systems out there with them, when they go its upgrade time. Be lucky to find any knocking about i reckon other than old stock. Deff not made anymore, i have a few systems out there with them, when they go its upgrade time. Be lucky to find any knocking about i reckon other than old stock.
djr69uk Posted March 19, 2011 Author Posted March 19, 2011 If I struggle to find a fob then can I use an RKP that works with the 593? The link of the one from the RS components site in my 1st post suggests it works with the 593... can anyone confirm? Thanks
djr69uk Posted March 19, 2011 Author Posted March 19, 2011 If I struggle to find a fob then can I use an RKP that works with the 593? The link of the one from the RS components site in my 1st post suggests it works with the 593... can anyone confirm? Thanks I meant can I use a G-Tag compatible RKP that works with the 593 - such as in the link.
MrHappy Posted March 19, 2011 Posted March 19, 2011 I've got a Gardtec 593 with contour LCD (7 segment) keypad and it doesn't get used as often as it should due to the keypad entry having become a chore! are your very lazy or are the buttons worn out ? Mr Veritas God
PeterJames Posted March 19, 2011 Posted March 19, 2011 I have three brand new Ace fobs you can have for £20 each plus P&P
