Gardtec 593
djr69uk
If I struggle to find a fob then can I use an RKP that works with the 593?
The link of the one from the RS components site in my 1st post suggests it works with the 593... can anyone confirm?
Thanks
The 593 will require a six wire keypad, the one in your link is almost certainly the newer 4 wire type so no it probably wont work.
Edit - Manufacturers Part No. 01152PA4W, no it wont work on your control panel.
Originally said by Charles Babbage
On two occasions I have been asked [by members of Parliament], 'Pray, Mr. Babbage, if you put into the machine wrong figures, will the right answers come out?' I am not able rightly to apprehend the kind of confusion of ideas that could provoke such a question.
  • 2 months later...
Does any one have any advice - we have a Gardtec 593 that has been going off every hour over night. The keypad says 'Check Battery/Fuse'; we're going to change the battery, but is there anyway to turn the alarm/bell off? Thanks
