Taco Posted March 22, 2011 Posted March 22, 2011 anyone know what the codes of practice are re: 6monthly/yearly inspections on intruder systems, and what checks MUST be carried out to conform to standard? Every day is a school day
itesecurity Posted March 24, 2011 Posted March 24, 2011 anyone know what the codes of practice are re: 6monthly/yearly inspections on intruder systems, and what checks MUST be carried out to conform to standard? Check and double check EVERYTHING .
Taco Posted March 25, 2011 Author Posted March 25, 2011 Check and double check EVERYTHING . yeh, i know that......i was actually looking for what the likes of NACOSS expect you to do Every day is a school day
miaren Posted March 25, 2011 Posted March 25, 2011 Give up, no one will answer....as that information is of value and not freely available....(members only (SSAIB & NSI)) no offence meant, just as it is.
MrHappy Posted March 25, 2011 Posted March 25, 2011 Lol, A model pmv was in 4737. Using you co. Manual to flesh it out Get on site, flash id badge, check against spec / on site docs, wall test, measure volts current & circuits, bells plus REM signals record in log bog ECT.. (Best I can do off a phone ) Mr Veritas God
norman Posted March 26, 2011 Posted March 26, 2011 also full set test where possible, not just toggling o/p's. On larger sites where bi-annuals then document which devices are tested as you may not do 100% per visit, but must do 100% over 12m. Document any changes/shortcomings and advise of no PA's whilst you have the system on test. Nothing is foolproof to a sufficiently talented fool.
A-G Posted March 26, 2011 Posted March 26, 2011 Something like this: The alarm system detailed in this design proposal will be maintained in accordance with the EN 50131-1:2004/PD6662 and DD CLC/TS 50131-7:2003 series. 2 maintenance services will be carried out per year, consisting: A Test tamper detection B Test setting & unsetting C Check entry & exit procedures D Test power supply & circuits E Test operation of detectors F Operation of warning devices G Test operation of ATE . . . . PM me for access to the SSAIB members discussion area.
Oxford Posted March 26, 2011 Posted March 26, 2011 Flash badge Put in eng mode Drink tea Take out of eng Get siggy Do one.
abbz Posted March 26, 2011 Posted March 26, 2011 just out of curiosity how many actually check tampers on all devices during a routine maintenance.
