Intruder Alarm Routine Inspection
Taco
This is what we use
Do you really do all those checks for every maintenance reidy? :fear:
Check bell delay(if programmed) and shut off times
on every maintenance?
I wonder how many check every tamper circuit/
:ninja:
:ninja:
That's the form we got from the NSI, so I guess that's what they think we should be doing
Hey Ho, Lets Go
just out of curiosity how many actually check tampers on all devices during a routine maintenance.
Never checked all tampers but more than often checked some. Bell delay done on full set check.
Why do you ask anyway?
i asked because every maintenance sheet i have ever seen always has that on it.
if we were to check all tampers we wouldnt get as many calls done and im sure cause more problems then when we started
The same will bell cut off timers.
im sure the majority of engineers never test that feature and just rely on there judgement taking into account the age and condition of the bell in general.
Indeed, i just ping a random sensor. If you start opening all PIR's, that's a guaranteed call out later that night :whistle:
depends on size, complexity & risk.
tamper wise, tend to rotate selected each visit. using fsl is an advantage.
How is using fsl an advantage ?
the tamper could still be disconnected inside the detector can it not
It could but it should have been checked on commissioning of the system and if its set up for engineer/anti code no one can open a device without you knowing.
  • 1 month later...
