SnAzBaZ Posted March 28, 2011 Posted March 28, 2011 Hello, I have a Scantronic 65EN fitted with some 9953 keypads of which one has an AX10 external tag reader fitted to it. It's my understanding that the AX10 can be used to unset the alarm from outside the building, just hold the tag up to it and it unset's. The installer is telling me that I have to press the tick on the keypad (inside the building) after holding the tag up to the AX10. Can someone tell me if the system can be programmed to unset one partition automatically (without pressing any buttons on the keypad) when a tag is presented to the AX10? Thanks!
MrHappy Posted March 28, 2011 Posted March 28, 2011 The installer is telling me that I have to press the tick on the keypad (inside the building) after holding the tag up to the AX10. Unless you start an entry timer the tag needs you to choose which areas you require to unset by use of the keypad Mr Veritas God
Monty Posted March 28, 2011 Posted March 28, 2011 hav,nt used the En 65 but we do fit the menvier M range and use the Ax10 remote reader and you can progg the tag to be set/ unset/access/reset/area set almost what ever you want and no need to use keypad works a treat www.AllanMoncrieffAlarms.com
SnAzBaZ Posted March 28, 2011 Author Posted March 28, 2011 hav,nt used the En 65 but we do fit the menvier M range and use the Ax10 remote reader and you can progg the tag to be set/ unset/access/reset/area set almost what ever you want and no need to use keypad works a treat That makes more sense to me, having to press buttons on the keypad after tagging with the reader makes having the reader pointless. The only use for it would be as part of an access control system to unlock a door. I simply want it to unset a specific partition, no need for it to be used for anything else. Thanks
MrHappy Posted March 28, 2011 Posted March 28, 2011 That makes more sense to me, so all you have to do is retain the reader, tags & detection ect & just replace the endstation, 3 x rkp & any expanders & bobs your uncle.... Mr Veritas God
Monty Posted March 29, 2011 Posted March 29, 2011 have a word with tec as some of the key pads work with the 65 range Keypads work with the Mrange as they are the same mother boards and just loaded with scantonic or Menvier so you could possibly get your rep to reload the panel you have on the wall ?? www.AllanMoncrieffAlarms.com
hpotter Posted March 29, 2011 Posted March 29, 2011 It's my understanding that the AX10 can be used to unset the alarm from outside the building, just hold the tag up to it and it unset's. yep. with manager code set up fob to required partitions and prog as easy set.
