sixwheeledbeast Posted March 30, 2011 Posted March 30, 2011 When the alarm is activated, then the soundbomb kicks in together with the external sounder. The method suggested in your post would only mean that I get a soundbomb when the alarm is triggered. Is this such a bad installation that needs to be changed? However as you rightly said, I have a Quad Piezo internal sounder and not a speaker. I understand the reason, this is why I suggested a speaker in an older post. It does need to be changed, that output is only designed for a 16ohm load. If you still want the loud noise on activation, wire the soundbomb with the bell. Our apprentice apparently blew a Veritas panel wiring a soundbomb into the speaker output, for what they cost you may as well have it right http://www.securitywarehouse.co.uk/catalog/index.php?main_page=product_info&cPath=36_45&products_id=662 As mentioned wiring a soundbomb across the speaker terminals is/may well blow the speaker output. Extension speaker as above is best all round.
zurrieq Posted March 30, 2011 Author Posted March 30, 2011 I understand the reason, this is why I suggested a speaker in an older post. It does need to be changed, that output is only designed for a 16ohm load. If you still want the loud noise on activation, wire the soundbomb with the bell. As mentioned wiring a soundbomb across the speaker terminals is/may well blow the speaker output. Extension speaker as above is best all round. Noted guys... will fix as instructed: Connect the red wire from sounder to Control Panel (A) + 12V Connect the black wire from sounder to Control Panel (B) Bell -
