Cant Clear Tamper
An outstanding problem on my Gardtec 595 panel.
History
RKP was locking up on set as a fire zone has no area assigned to it. Power cycle and reassigning zone to Area1 sorted this but when trying to set the system am getting a Tamper on this zone and says I cant set (Error reads SMOKE HALL T!)
I have tried clearing the tamper in usual way to no avail (tampers are set to any code reset).
Could the original RKP lock out problem have caused another problem, is there something different to do to clear a fire sensor indocated tamper??
My ideas - wiring should be fine as has not been touched, thought about removing power to the sensor and see if this clears it
Any other bright ideas anyone
Sorted pretty easily. Went to swap zones 3 and 4 over on the panel just to check if something crazy was happening with the fire zone (zone 4). In doing so noticed I'd trapped the tamper wire when putting back the panel cover - remade connection and all well.
I love it when its simple :):):)
