ChuckUK Posted April 14, 2011 Posted April 14, 2011 Hi all, I have a faulty PIR that needs replacing, the model is a Ademco Aurora. Can anyone recommend a replacement ? I can't seem to find this particular brand in the UK.
sixwheeledbeast Posted April 14, 2011 Posted April 14, 2011 Hi all, I have a faulty PIR that needs replacing, the model is a Ademco Aurora. Can anyone recommend a replacement ? I can't seem to find this particular brand in the UK. This appears to be a pet immune PIR is there a reason for this? Any pet immune PIR will do, if this is required.
ChuckUK Posted April 14, 2011 Author Posted April 14, 2011 This appears to be a pet immune PIR is there a reason for this? Any pet immune PIR will do, if this is required. We have two dogs, any particular brand you would recommend ?
norman Posted April 14, 2011 Posted April 14, 2011 Schnauzer, they do not moult. Nothing is foolproof to a sufficiently talented fool.
sixwheeledbeast Posted April 14, 2011 Posted April 14, 2011 We have two dogs, any particular brand you would recommend ? Visonic K9-80 are okay, but mounting heights are very important with pet immune so expect to move the cable if the PIR is to high/low. If your dogs combined weigh 80lb you may have to consider a different option. Many installers would fit/recommend perimeter protection in that area for this reason.
