Control Box Tamper
Help
The Control box tamper is triggering about once a week on a Gardtec 595 panel.
Seems to be related to when the case gets warm in this unseasonable weather (case is in loft).
Is this a simple matter of pulling the spring contact a bit so it sits harder against the case and thus stops these false trips. I am worknig on the assumption that the case tampe circuit is a normally closed one through the spring/case and return wire that is tagged on the case and back to the main PCB.
cheers anyone as this is becoming annoying - esp when it's in the middle of the night.
Hi Paul,
just extend the spring and all should be ok.
Thats one thing that annoys me about that panel with the spring on the front of the PCB.
