jmsjabb Posted April 28, 2011 Posted April 28, 2011 Can someone tell me if I use a BNC T adaptor on a camera feed, can I send the feed to two devices? If so, will there be a reduction in quality if split?
camullins Posted April 28, 2011 Posted April 28, 2011 Can someone tell me if I use a BNC T adaptor on a camera feed, can I send the feed to two devices? If so, will there be a reduction in quality if split? Yes there will be a reduction in quality/problems. Loop in/out of a monitor or get a 1 in 2 out amp.
SystemQ Posted April 29, 2011 Posted April 29, 2011 Can someone tell me if I use a BNC T adaptor on a camera feed, can I send the feed to two devices? If so, will there be a reduction in quality if split? Hi. If its the AlienProlite, this already has video loop throughs, this would give you the video split. They are on a separate plug-in cable loom on this model, if you have lost or misplaced this item let me know and I can send it you. , Paul. System Q Ltd.
jmsjabb Posted April 29, 2011 Author Posted April 29, 2011 Hi. If its the AlienProlite, this already has video loop throughs, this would give you the video split. They are on a separate plug-in cable loom on this model, if you have lost or misplaced this item let me know and I can send it you. , Paul. Yes it is a pro lite. I didn't realise it had the loop, as the holes were blanked off. I would love to do this so I can send the signal on to my old vista machine for viewing on my mac.
