Galaxy 18 To Dial Mobile ?
I have a ex ADT galaxy 18, Chip V2.31 ADT, which I can get to call my Mobile, but it will ring it 10 times on each alarm activation. I have all the codes, and I am able to programme it OK.
I believe the ADT panels have a restricted menu as I cant access all the items. I read somewhere a while ago that I need a later version (Ver 4 something)to get full control of the Dialler, but I am not sure whether it is Ver 4 of the dialler or the motherboard I need ? The Dialler is V4.04 (I believe)
I have got a spare G18 board with a V4.06 chip on it, will this help ?
Can I just swap the chip over, or do I need to change the whole board (I know it would need to reprogrammed) ?
Thanks in advance
Keith
Yes, I agree. I did look at the Menvier SD1+, but I am off work at the moment due to surgery, and looking for things to amuse me. The cost was also a factor unless anyone has one going cheap ?
The "dailer" on panel is expecting an alarm reciever to answer the call. It will keep dailing the number for the number of attemps programmed untill it gives up.
Buy a speed dailer =]
I can mimic handshake and kiss off, sad but true.
Guest chris
have you thought of using the sms facility??
set it up, obtain your mobile providers message centre number, program it in and its all good.
thats how i got my 60 set up, it works great
