frankygee Posted May 8, 2011 Posted May 8, 2011 Hi all, first post. I usually deal with CCTV, but a client asked if I would take a look at his door entry. I have done a couple of audio and video entry insallations but this problem is a bit out of the way. The client has a 3 way audio unit with door release. It's an ACET 21227 He wants an additional entry panel on an external door and the door release moved to this external door. Only the external door needs to be electronically unlocked, but the intercom should work with the external and internal door. Is is possible to purchase the same model entry panel and wire it in parallel or am I being to simplistic. If further info is required, please let me know. Thanks in advance. Frank
MrHappy Posted May 9, 2011 Posted May 9, 2011 Is is possible to purchase the same model entry panel and wire it in parallel or am I being to simplistic. normally the manufacters does a interface kit for multi entrances (I use videx or urmet) Mr Veritas God
frankygee Posted May 11, 2011 Author Posted May 11, 2011 I've tried googling ACET but could not find any way to contact them. Do you know of any resellers in the UK.
Cubit Posted May 11, 2011 Posted May 11, 2011 I've tried googling ACET but could not find any way to contact them. Do you know of any resellers in the UK. Seurefast - Southport. They should be able to help. They own the company/assets.
