IAS Posted May 11, 2011 Posted May 11, 2011 first fixed a call center yesterday, fishing our expander feeds across an old mill thats been converted, however the data guy turned up today and said I have to remove my alarm cable from the box trunking the customer supplied between the two buildings because it will cause interference as quote "the pulses it generates will interfere with the server and destroy the broadband connection to the phone system" thoughts please.
alterEGO Posted May 11, 2011 Posted May 11, 2011 bullsh!t, tell customer about it(before he does) and say you will move if it causes a problem.
reidy Posted May 11, 2011 Posted May 11, 2011 Unless your planning to send mains down that alarm cable you should be fine Hey Ho, Lets Go
Cubit Posted May 11, 2011 Posted May 11, 2011 He's talking out of his hole. ask the retard if he's checked the mains supply for balanced load and acceptable power factor. that will sort him. As Aaron says, get to customer first.
IAS Posted May 11, 2011 Author Posted May 11, 2011 customer was stood at the side of me and agreed - whats the point spending another 2K running more galv. on a theory.
Cubit Posted May 11, 2011 Posted May 11, 2011 and why does the cat5 cable monkey think his system will be affected when no one else's is?
jnealon Posted May 11, 2011 Posted May 11, 2011 Complete nonsense, I.T guy is probably nothing more than a cable monkey. www.realsecurity.ie
MrHappy Posted May 11, 2011 Posted May 11, 2011 thoughts please. in our gaff the data cabling has got 50 volt POE + 50 volt BT lines + RG59's & a ACT2000 which runs back to server cab patchesatchs across a panel & back to PC's serial port all over cat5. if he's asked for containment just for data, fair do's to him. I'd be more than happy to move at the clients cost or trunk inside the exisitng trunking Mr Veritas God
miaren Posted May 11, 2011 Posted May 11, 2011 Yep, must agree...I'm with them 12V alarm data lines cause interference on 50V BT, network cables other cables.??? Can you use screened and stick his thoughts somewhere..
IAS Posted May 11, 2011 Author Posted May 11, 2011 in our gaff the data cabling has got 50 volt POE + 50 volt BT lines + RG59's & a ACT2000 which runs back to server cab patchesatchs across a panel & back to PC's serial port all over cat5. if he's asked for containment just for data, fair do's to him. I'd be more than happy to move at the clients cost or trunk inside the exisitng trunking ah - quote "yes electric guys might all ways run cables like that but that doesnt mean they know that they arn`t doing it wrong" to put him in perspective, he said to delay the alarm for a month to prove his phones worked, I suggested that if it did cause a problem then we could (at the customers expense) run trunking inside the trunking - about 75mtr, six changes in direction and a suspended bit between two walls ....... he insisted it would be easier and cheaper to do it in 20mm galv tube inside the trunking. I went off to find a kettle.
