agfireandsecurity Posted May 12, 2011 Posted May 12, 2011 Hi, has anyone got any information on the Chubb Zonemaster 404 control panel? Is it a conventional panel? or are the bases and smoke heads unique to that panel. I am trying to replace one of these with a Kentec conventional panel, but when i activate a head with some smoke i get a fault on that zone instead of a fire. I have tried wiring a head and base directly onto the panel, but still get a fault???/ thanks in advance Gary
CerbNI Posted May 12, 2011 Posted May 12, 2011 Not wanting to sound mardy but would it not have been better checking compatibility before fitting the Kentec non-addressable?
agfireandsecurity Posted May 13, 2011 Author Posted May 13, 2011 What heads are the exisitng ones ? The Bases are marked as follows: Chubb Fire YBC-RL/4H5C and the heads are Photo electric smoke detector Model Number F3190077 Thanks for your reply
MrHappy Posted May 13, 2011 Posted May 13, 2011 I assume conventional hochiki? Before I try & help you, why are the controls being changed in the 1st place? Mr Veritas God
FGS_Alarms Posted May 27, 2011 Posted May 27, 2011 I have come accross this problem a few times. Chubb use their own heads which are only compatable with Chubb panels. You will need to replace all of the detectors and bases with ones compatable with the Kentec system I'm affraid. Out of interest what was the reason for changing the panel?
