m2000 Posted May 14, 2011 Posted May 14, 2011 Hello, recently had an ADT system fitted. Its a wireless setup, the ADT Quick-Connect. It appears that this system is basically a re-badged Honeywell Domonial system. Can anyone confirm this? I want to give some members of our family proximity tags rather than relying on them having to use codes to arm/disarm. Can any of the honeywell prox tags, ie. the ones for the Galaxy system, work with my system? Also, how easy is it to add more detectors to the system, or is it a case of ADT coming out at some stupid rate? Thanks!
IAS Posted May 14, 2011 Posted May 14, 2011 On 14/05/2011 at 13:30, m2000 said: Hello, recently had an ADT system fitted. Its a wireless setup, the ADT Quick-Connect. It appears that this system is basically a re-badged Honeywell Domonial system. Can anyone confirm this? I want to give some members of our family proximity tags rather than relying on them having to use codes to arm/disarm. Can any of the honeywell prox tags, ie. the ones for the Galaxy system, work with my system? Also, how easy is it to add more detectors to the system, or is it a case of ADT coming out at some stupid rate? Thanks! did you not wonder why it was so cheap to start with? as the system is under contract only ADT can work on this, you`ll be tied in till the term ends then you can shop around.
reidy Posted May 14, 2011 Posted May 14, 2011 Its also a rental deal if I remember correctly Here's the T&Cs http://www.adt.co.uk/document-downloads/Corporate-documents/ADT%20QuickConnect%20Terms%20and%20Conditions%20Aug2010-ADT1055.pdf Hey Ho, Lets Go
norman Posted May 14, 2011 Posted May 14, 2011 OP, the tags are circa £8 each, they can be posted out to your home and programmed remotely without the need for an engineer. where abouts in the country do you live? Nothing is foolproof to a sufficiently talented fool.
m2000 Posted May 14, 2011 Author Posted May 14, 2011 On 14/05/2011 at 17:10, norman said: OP, the tags are circa £8 each, they can be posted out to your home and programmed remotely without the need for an engineer. where abouts in the country do you live? Hi, I am in Manchester. So ADT still need to "code" each of the tags, but it can be done by them dialling in? Thanks On 14/05/2011 at 17:10, reidy said: Its also a rental deal if I remember correctly Here's the T&Cs http://www.adt.co.uk/document-downloads/Corporate-documents/ADT%20QuickConnect%20Terms%20and%20Conditions%20Aug2010-ADT1055.pdf Yes, it's a three year deal Inc monitoring, maintenance and call outs. £20 a month. I got the install for less than advertised on website. Apparently, although they reserve title t the goods, they have a policy of not removing after the 36 months period. Its a nice little system, in my opinion anyway, I got the pet friendly plus fire option.
norman Posted May 14, 2011 Posted May 14, 2011 On 14/05/2011 at 17:35, m2000 said: Hi, I am in Manchester. So ADT still need to "code" each of the tags, but it can be done by them dialling in? Thanks speak to your local branch on 0161 252 5573, they should be able to arrange for the fobs to be posted out and once received you can ring and get them programmed via resolve.Some more useful info here... http://www.adt.co.uk/company-information/help-residential-customers Nothing is foolproof to a sufficiently talented fool.
m2000 Posted May 14, 2011 Author Posted May 14, 2011 On 14/05/2011 at 17:43, norman said: speak to your local branch on 0161 252 5573, they should be able to arrange for the fobs to be posted out and once received you can ring and get them programmed via resolve. Some more useful info here... http://www.adt.co.uk/company-information/help-residential-customers Thanks for that matey. I have seen the fobs for sale online for the Honeywell Domonial system which is the same one as mine I believe. Could I buy them from the net (about a fiver each). And then ask ADT to dial in and programme them? OR will ADT only programme up ones they supplied? Another question mate, will they charge for the remote programming? Thanks a lot for your help
norman Posted May 14, 2011 Posted May 14, 2011 yes they should, and no they shouldn't. Nothing is foolproof to a sufficiently talented fool.
The Arab Posted May 22, 2011 Posted May 22, 2011 If you buy fobs online etc you can programme them yourself without having to get resolve to dial in as long as you have a master code or fob,if you get stuck pm me and I'll give you instructions, basically press right or left arrow it'll ask for master code or fob you'll then get a drop down menu press eft or right again till you have users highlighted,press ok, it'll then say fobs or codes,left or right again till fobs is highlighted press ok, then select a user number that hasn't been used press ok then follow screen instructions on screen, but watch if you select a user number already in use you'll overwrite the old fob with the new one Trade Member
