norman Posted May 25, 2011 Posted May 25, 2011 use sia if you want zone decriptions Nothing is foolproof to a sufficiently talented fool.
9651 Posted May 25, 2011 Posted May 25, 2011 It *may* work, but still show SMS com fail. (tried it on a RI). Good stuff with the Gal. You can turn the E/E tones off loud speaker, and just have keypad, you still get the setting (loud) confirmation 'beep beep'. For some reason on the 2 series the volume control in the parameters makes no difference. If you want some kind of notification, i'd suggest a SD2 speech dialler.
9651 Posted May 25, 2011 Posted May 25, 2011 Thgink he's on about the 16 ohm loud speaker fella They are LOUD on 2 series
norman Posted May 25, 2011 Posted May 25, 2011 still not a volume control inside the rkp though is it. /some engineers! Nothing is foolproof to a sufficiently talented fool.
alterEGO Posted May 25, 2011 Posted May 25, 2011 use sia if you want zone decriptions I know that, but that and OC is the only use for it.
Guest Galaxy Posted May 25, 2011 Posted May 25, 2011 still not a volume control inside the rkp though is it. /some engineers! Another method box side out think
jonm Posted May 28, 2011 Author Posted May 28, 2011 Just to clarify, as 9651 said its the speaker sound that is loud. There are 2 speakers that were used with the 9800 old panel as internal sounders, but now, with the galaxy, the entry / exit tones sound through them as well, making the entry exit seem quite loud throughout the house! We need to retain the speakers as they still act as the internal alarm sounders. Maybe I could have the volume turned down, will probably get used to it tho!
9651 Posted May 28, 2011 Posted May 28, 2011 Can be done only through engineer parameters. If the keypad/loud speaker is by the E/E door, the volume can be turned off. The set confirmation (beep beep) will still work (loud) and alarm tones will still be at full volume.
