Adi Posted May 15, 2011 Posted May 15, 2011 Do you allow a 2 year old baby to use your phone? Then why shower it with K band from a PIR? Mine does, but we've had to put a cap on his text's coz its just been getting out of hand lately. We have also turned the internet connection off because he was just no stop posting on facebook, not good in my opinion. I really can't be ar**** with it anymore.
Cubit Posted May 15, 2011 Posted May 15, 2011 If when the system is disarmed you switch the panel power off so that the PIRs do not work, will this screw up the programming? No, but the world might come to a sudden end. Especially with allthem rogue microwaves still bouncing around. We're doomed i tell ye, doomed.
IAS Posted May 15, 2011 Posted May 15, 2011 it`s them fridges you want to watch out for .......................pah
MrHappy Posted May 15, 2011 Posted May 15, 2011 If when the system is disarmed you switch the panel power off so that the PIRs do not work, will this screw up the programming? an alarm should have a battery, turning the power of to the system should have no effect on whether the detection is powered if you really want your microwaves turning off ask the installer to can them to pir's or g3 greenlines set up of an output Mr Veritas God
Agios Adelfos Posted May 16, 2011 Author Posted May 16, 2011 an alarm should have a battery, turning the power of to the system should have no effect on whether the detection is powered if you really want your microwaves turning off ask the installer to can them to pir's or g3 greenlines set up of an output Thanks for the advice MrHappy
sixwheeledbeast Posted May 16, 2011 Posted May 16, 2011 Basically there is no clear report stating if the emission of Microwaves is dangerous and what are its effects. Ideally I would like to have them off when the building is occupied and the system is disarmed. I have the Galaxy G2-44 panel. I was wondering if there is any way to stop the power to the PIRs when the system is disarmed. The DT's will require replacing as mentioned, the dual-tech sensors can take up to a minute on power up to "warm-up". (Excuse the pun!) So removing the power is not an option. I really wouldn't be worrying about emissions from a DT, I have tested most Dual-Tech's with a microwave emissions tester and there is absolutely no reading. I would be more worried about mobile phones and your microwave. Upon testing some mobile phones the reading can reach 4-5mW/cm2 while ringing and 2-3mW/cm2 while on the phone. As for microwave ovens just a dirty seal on the door and your emitting up to 11mW/cm2 into the whole kitchen. Also you'll be surpised how many recently bought cheap microwaves fail on the window you stare at your meal through.
PeterJames Posted May 16, 2011 Posted May 16, 2011 Read and Learn http://www.tycoemea....der/psi286A.pdf I suspect that that warning is there to protect Risco at a later date should (And I stress this is highly unlikely if you know anything about the theory of Radar Dopler) something ever be discovered in the future The truth is your mains electricity cables are radiating radio signals, your wifi is radiating radio signals, even your tv is radiating, I could go on and on. Ive been in this industry for 30 years and Im ok, my predecessor has been in this industry longer still no effects of radiation from MW and we work inch's away from them My advice if you really are concerned about radiation from your detectors is change them for passive infra reds.
norman Posted May 16, 2011 Posted May 16, 2011 beware of the passive infra red beams also, they are evil. Nothing is foolproof to a sufficiently talented fool.
Cubit Posted May 16, 2011 Posted May 16, 2011 Considering there is sod all power coming out of them, factor in the inverse square law with regards to power dissipation it is fair to say natural ground radiation will present more of a danger. You have to go some to get affected by microwave transmission - and there is little kit about available to joe public that can do it - without fannying about with safety interlocks.
MrHappy Posted May 16, 2011 Posted May 16, 2011 whilst on the subject of harmful radar emissions, Golden Earring must rank pretty high? Mr Veritas God
