Id Plus Contacts
As I said that was a fitting issue but the moisture made readings false and so you were heading off to the wrong ID device.
Had 1 site that drove me crazy, throwing up faults all over the place. Turned out to be due to 2 biscuits fitted into unsealed external enclosures, ok not actually an ID fault but it would have been a lot easier to narrow it down on a DP or DEOL circuit.
I installed my first ID system over 20 years ago, with an ADE Ultimate panel. I have been fitting ID (where appropriate) ever since. I have not experienced any particular issues with either performance or fault finding ID and can honestly say that it is no more or less reliable than either DP or EOL. The system installed in 1992 is still working absolutely fine with no issues (except when a squirrel chewed through a cable in the attic), was monitored with Police response from day 1 and still has response now.
As a circuit monitoring technology I think ID is absolutely brilliant and will continue to install it until it becomes unavailable.
The technology was originally invented (I believe) in America and was intended to provide switch monitoring for machines. As Honeywell now own the ADE brand which originally bought the rights to ID in the UK you rightly observe that they probably have little interest in it, but it is still probably earning them money as a number of other manufacturers took on ID and still produce equipment for it. I suspect that ID will still be around in one form or another for many years yet......
I thought it was developed for use in cars. I don't think it will be around for long, if it could do mask etc then it would do longer. Addressable detectors and RF will take over imo
Correct the technology was developed for the auto trade, and the biscuits now are obsolete
amealing@texe.com
Head of Industry Affairs
Visit Our Website
Texecom
A dedicated data line and RIO's kind of put paid to ID Biscuits I thought? You can do so much more for essentially running the same cable around site.
iD biscuit came after these ?
If you can do the basic of alarms (terminate devices correctly) iD was a nice stable technology & no more hassle than DP or EOL.
Done poorly a iD system is f'kin nightmare
Yep, branches everywhere!!!!
Brilliant.....................................................
Forgot. Uses all the spare chips and no sketch :D
I have no experience with iD. Other than cost implications I can't see any benefit it offers an installer compared to a data line? Or was it just another way to skin a cat.
