Galaxy G3-144 Timed Set Display Missing
johno63
updated a system with a new powered rio and keypad on line 2, the keypad on line 1 all ok, line 2 keypad when setting with the fob it does not display the coundown timer or zones that are open, and cant stop setting with esc key. will only stop if you present fob again. if you input code and a system sets as normal,,,, no groups are programmed in, keypads addresses all ok, tried re-addressing keypads, swopped keypads over, restarted panel, anyone help please spend 3 hours trying to sort out
thanx
johno
