Cubit Posted May 18, 2011 Posted May 18, 2011 Data around the ring is all encrypted between the transmitter and receiver. The manufacturer of the oe slips my mind but if I remember its nothing too special. Single phase mains as found in domestic applications. Does anyone concur that this would work? I wouldn't. Them devices are ok for the odd IP point or for say, the typical data connections around the home/small office, but you're gonna hit a bottleneck somewhere with 7 camera's on them. The whole thing smacks of doing a bodge so the 2 bob millionaire can save a few quid.
reidy Posted May 18, 2011 Posted May 18, 2011 Data around the ring is all encrypted between the transmitter and receiver. The manufacturer of the oe slips my mind but if I remember its nothing too special. Single phase mains as found in domestic applications. Does anyone concur that this would work? I don't think the security would be that much of an issue given the application, they are very useful little devices I think it SHOULD work, however its a lot more complicated and expensive than a bit of cable Cubit makes a good point about bandwidth Hey Ho, Lets Go
mma Posted May 19, 2011 Posted May 19, 2011 Data around the ring is all encrypted between the transmitter and receiver. The manufacturer of the oe slips my mind but if I remember its nothing too special. Single phase mains as found in domestic applications. Does anyone concur that this would work? Don't think it would work in this application as it does need to be the same ring throughout. Won't work in my house. 1 ring upstairs and 1 down. Have you considered running the cable outside say down the back of the building in pipe. Could use cat5 cable and get 4 cams off each cable. Or get animal print cable. What kind or 70s decor place is it. Sound like my grandad would like it.
whistle Posted May 19, 2011 Posted May 19, 2011 We put 300m of animal print cable on a job a few weeks ago, found it very good...
norman Posted May 19, 2011 Posted May 19, 2011 Sound like my grandad would like it.It is your Gramps, he asked Oxford to do it because he said you are ****. Nothing is foolproof to a sufficiently talented fool.
MrHappy Posted May 19, 2011 Posted May 19, 2011 Sound like my grandad would like it. I thought the install was lap dancing club? Mr Veritas God
norman Posted May 19, 2011 Posted May 19, 2011 it was... Nothing is foolproof to a sufficiently talented fool.
mma Posted May 19, 2011 Posted May 19, 2011 I thought the install was lap dancing club? You clearly haven't met my grandad. Right up his street.
MrHappy Posted May 19, 2011 Posted May 19, 2011 You clearly haven't met my grandad. Right up his street. how thongs have changed.... Mr Veritas God
