Riggy Posted May 18, 2011 Posted May 18, 2011 Quoting for my third CCTV install (I'm an electrician), customer wants picture in picture. Customer deals in fencing materials, timber, etc. His house backs onto his yard. Mounting a couple of cameras on the gable end of his house will cover the yard fine, DVR and monitor to go in kitchen (which doubles as an office), all good. He would like picture in a picture image on his living room TV. We're are all digital around here now, and he has Sky+ on the TV he wants to display the CCTV image as picture in picture. Any ideas?
MrHappy Posted May 18, 2011 Posted May 18, 2011 assume one tv, then its just a monitor feed to a telly which supports piture in piture? Mr Veritas God
Riggy Posted May 18, 2011 Author Posted May 18, 2011 assume one tv, then its just a monitor feed to a telly which supports piture in piture? Yes, that's it.
MrHappy Posted May 18, 2011 Posted May 18, 2011 **wacks keyboard to get "c" working ** Yes, that's it. simple then rg59 to telly, bnc to phone connect up to av input or scart via convertor source "a" the hdmi, scart or however his sky is pipped in soucre "b" the cctv input all sorted Mr Veritas God
Neutech Posted May 19, 2011 Posted May 19, 2011 Just make sure his TV does PIP from an AV source as some only do PIP on TV tuner channels Other way is set up a redwall / IR Beams and use it to trigger the Scart switch function on TV but remember to put a switch to disable that function so it isnt switchin all the time when he isnt wanting to be watching it, at least he'll get full screen picture when it flicks over Diagram for scart hook up Pin 8 read the notes below http://www.electronics2000.co.uk/pin-out/scart.php
sixwheeledbeast Posted May 19, 2011 Posted May 19, 2011 Other way is set up a redwall / IR Beams and use it to trigger the Scart switch function on TV but remember to put a switch to disable that function so it isnt switchin all the time when he isnt wanting to be watching it, at least he'll get full screen picture when it flicks over Another other way is to take his composite sky signal to the DVR on a spare channel (set not to record) and use the PIP on the DVR. If there are enough composite inputs you can have (full screen sky / full screen cctv / PIP). This may require a good few cables between the DVR and the Sky box tho (3/4 RG's). Is it Sky HD or SD?
