Avinitlarge Posted May 18, 2011 Share Posted May 18, 2011 Ive just picked up a VCL PTZ. Ive powered it up and connected it to a TV just to test it. I think its working ok but I'm not 100% sure. It displays a picture but the camera is set to some sort of sequence. The dome is turning, the camera is tilting, zooming and focusing, it just keeps on repeating the same sequence over and over. I was hoping to connect this to my computer via a RS232 to RS485 adaptor, when I plug the adaptor into the computer using a free trial of some PTZ software I can't control the camera. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/31650-vcl-ptz-help/ Share on other sites More sharing options...
RichL Posted May 18, 2011 Share Posted May 18, 2011 check that the protocols are the same eg Pelco D at camera and controller. Originally said by Charles Babbage On two occasions I have been asked [by members of Parliament], 'Pray, Mr. Babbage, if you put into the machine wrong figures, will the right answers come out?' I am not able rightly to apprehend the kind of confusion of ideas that could provoke such a question. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/31650-vcl-ptz-help/#findComment-273638 Share on other sites More sharing options...
Avinitlarge Posted May 18, 2011 Author Share Posted May 18, 2011 Ive seen the setting on the software but Im not sure about the setting on the camera. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/31650-vcl-ptz-help/#findComment-273639 Share on other sites More sharing options...
Avinitlarge Posted May 18, 2011 Author Share Posted May 18, 2011 Ah, I think I know what I am doing wrong. I only have the camera, no controller. Ive got the camera connected staight to the RS845 adaptor, is this wrong? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/31650-vcl-ptz-help/#findComment-273643 Share on other sites More sharing options...
digitalwitness Posted May 18, 2011 Share Posted May 18, 2011 Can you put up a link to the dome make/model and to the free ptz software. Quick check list: 1)Protocols 2) Baud Rates 3) Address 4) Polarity of RS485 5) Check data is being sent out the port when a function is selected (put an LED across the connections it should light when a signal is being sent) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/31650-vcl-ptz-help/#findComment-273644 Share on other sites More sharing options...
Avinitlarge Posted May 18, 2011 Author Share Posted May 18, 2011 This is the dome, externally it is different but the internals are the same http://www.honeywellvideo.com/documents/RDMU000995-B_Outdoor_RapidDomeGold_Installation.pdf This is the software, dont know if it any good though http://www.serialporttool.com/PTZ.htm Link to comment https://www.thesecurityinstaller.co.uk/community/topic/31650-vcl-ptz-help/#findComment-273645 Share on other sites More sharing options...
digitalwitness Posted May 18, 2011 Share Posted May 18, 2011 Is the dome RS422 or RS485? Manual says RS422 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/31650-vcl-ptz-help/#findComment-273649 Share on other sites More sharing options...
Avinitlarge Posted May 18, 2011 Author Share Posted May 18, 2011 Now im not 100% sure on that one. It could be 422 as the manual says. Ive got an adaptor on the way, will let you know how I get on with it. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/31650-vcl-ptz-help/#findComment-273653 Share on other sites More sharing options...
Avinitlarge Posted May 20, 2011 Author Share Posted May 20, 2011 I got the RS422 adaptor today Protocol Set to Pelco D on the PTZ and the software Baud rate tried them all Still nothing Link to comment https://www.thesecurityinstaller.co.uk/community/topic/31650-vcl-ptz-help/#findComment-273706 Share on other sites More sharing options...
digitalwitness Posted May 20, 2011 Share Posted May 20, 2011 Check that data is exiting the port each time a command is being sent. This will verify the basics are right with the PC and software before getting to protocols, etc. Can you describe all of the connections on the data line, from PC to PTZ and everything in between? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/31650-vcl-ptz-help/#findComment-273707 Share on other sites More sharing options...
