Humbert Posted May 27, 2011 Posted May 27, 2011 The siren on my Yale HSA500 system that I fitted many years ago has stopped working and I am unable to find a direct replacement. Can anybody advise what would be a suitable replacement wired siren for this particular alarm system.
9651 Posted May 27, 2011 Posted May 27, 2011 Christ thats a scantronic 500r!? Never seen one badged up as a Yale. How many connections are ther for the bell? Should be a 12v 0v Tamp Bell Trig Strobe (-) and possibly a Strobe (+) If they are marked up like this something like this should be ok http://cgi.ebay.co.uk/Honeywell-Intruder-Alarm-Bellbox-White-Blue-AG6-/220785950140?pt=UK_Burglar_Alarms&hash=item3367de3dbc#ht_571wt_905 If not you may need a multimeter to work out whats what depending how competent you are.
magpye Posted May 27, 2011 Posted May 27, 2011 Silmner I'm sure, but the 500r does not have a learn position above the keypad as does the HSA500 Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care.
Humbert Posted June 2, 2011 Author Posted June 2, 2011 Christ thats a scantronic 500r!? Never seen one badged up as a Yale. How many connections are ther for the bell? Should be a 12v 0v Tamp Bell Trig Strobe (-) and possibly a Strobe (+) If they are marked up like this something like this should be ok http://cgi.ebay.co.uk/Honeywell-Intruder-Alarm-Bellbox-White-Blue-AG6-/220785950140?pt=UK_Burglar_Alarms&hash=item3367de3dbc#ht_571wt_905 If not you may need a multimeter to work out whats what depending how competent you are. Many thanks for your reply. There are 6 terminals inside the unit marked Bell 1 and 2, Strobe 1 and 2, Tamp 1 and 2. I have a multimeter if you could give me some advice on what readings i should expect and in what alrm state I should take the readings
9651 Posted June 5, 2011 Posted June 5, 2011 I'd hazard a guess.... Bell 1+2........... One of these should be 12v, the other will switch 0v when the alarm triggers Strobe 1+2............ One of these will also be a 12v and one will switch 0v when the alarm triggers Tamper 1+2............. one of these will be a 0v, the other will be the tamper return. Most replacement sirens will only have 5 connections, disconnect the strobe in the panel
Humbert Posted June 5, 2011 Author Posted June 5, 2011 I'd hazard a guess.... Bell 1+2........... One of these should be 12v, the other will switch 0v when the alarm triggers Strobe 1+2............ One of these will also be a 12v and one will switch 0v when the alarm triggers Tamper 1+2............. one of these will be a 0v, the other will be the tamper return. Most replacement sirens will only have 5 connections, disconnect the strobe in the panel Many thanks again, I have bought the siren you recommended and will attempt to fit it when it arrives
Humbert Posted June 8, 2011 Author Posted June 8, 2011 I'd hazard a guess.... Bell 1+2........... One of these should be 12v, the other will switch 0v when the alarm triggers Strobe 1+2............ One of these will also be a 12v and one will switch 0v when the alarm triggers Tamper 1+2............. one of these will be a 0v, the other will be the tamper return. Most replacement sirens will only have 5 connections, disconnect the strobe in the panel Sorry to pick your brain again. The siren does have 5 terminals as you said, one is marked negative supply, can you confirm this should be connected to the tamper 0v terminal in the control box. many thanks
davedart Posted August 2, 2011 Posted August 2, 2011 Sorry to pick your brain again. The siren does have 5 terminals as you said, one is marked negative supply, can you confirm this should be connected to the tamper 0v terminal in the control box. many thanks I also have the same problem and have ordered a similar 5 wire unit. How did you end up connecting the new siren unit? Thanks
Humbert Posted August 20, 2011 Author Posted August 20, 2011 Hi Sorry for the late reply. Been away. In the end I did the following I bought a Intellisense AG6 external sounder and strobe. I connected BL1 to V+, BL2 to S-, TA1 to TR- and TA2 to V-. It works but the strobe is not working. Hope this helps
james.wilson Posted August 20, 2011 Posted August 20, 2011 what did you connect the strobe too? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
