Cctv Switcher
hi all hope you are all well.
do any of you no of a good remote switcher?
the job im for a friend is installing 3 monitors around the building so each area can monitor the camaras in that area but it isn't a option to run loads of cables from the dvr's to the switcher. so im looking for a unit where i can install the switch in the rack mount unit with the dvr's and instill a remote keypad setup at the viewing desk what they can use to control the switch.
any ideas guys?
Or you could look at DVR's with network access and just drop a simple PC at each location with the remote viewing software on them.
i did think of that but there network is s*@t and the IT people who run it or even worst.
Your going to fit in just fine around here :)
Hey Ho, Lets Go
Nortek do a version that carries the video image down the same cable = 1 run of Cat 5
Easy Peasy.
