Scantronic 9651 And Bell
Guest Lee
Hi, I wounder if anyone could please advise me on this?
I have a Scantronic 9651 Control Panel and I'm a little unsure as how to connect the external bell.
The Control Panel as the following connections:
OP1 OP2 TR 12vAUX 0v
I understand that OP1 and OP2 apply a negative, TR is for tamper and 12v/0v supply the power.
The bell box has the following connections:
STB+ STB- HOLDOFF+ HOLDOFF- RTN TRG
This is now I think they should wire together:
OP1 to TRG
OP2 to STB-
TR to RTN
12V to HOLDOFF+
0V to HOLDOFF-
I wanted to check this was correct before I connected for real in case I damage something.
Can you please advise?
Much appreicated!
