a1steve Posted June 7, 2011 Posted June 7, 2011 I am after some help I have got two videx sp300 door syatem one on the gate and one on the front door. I need to know is the relay for the maglock on the keypad bords or the main voice unit? because I am thinking off adding a paxton switch 2 access system on the front door and the gate instead off using codes
antinode Posted June 7, 2011 Posted June 7, 2011 Every intercom I have ever fitted, it has been on the door station. Don't know that particular model, but I don't see any reason why they'd put the relay in the handsets... doesn't make sense. Trade Member
Gringo154 Posted July 21, 2011 Posted July 21, 2011 Videx kit is a nightmare, every bit seems to be wired differently depending on what you match it with and instructions from technical read like Polish post codes. I just give them a ring, tech are pretty clued up
