doppy123paul Posted June 8, 2011 Posted June 8, 2011 Hi Could anyone help with a querry I have. My new client has a DM Sprite 2 16 channel dvr. The old service provider has left no info and I need to access the engineers menu. I've been given one engineering code but that one doesn't work. Rather than sending the unit back to DM would anyone please suggest any alternative codes I could use please Any suggestions would be greatly appriciated Thanks
camullins Posted June 8, 2011 Posted June 8, 2011 Hi Could anyone help with a querry I have. My new client has a DM Sprite 2 16 channel dvr. The old service provider has left no info and I need to access the engineers menu. I've been given one engineering code but that one doesn't work. Rather than sending the unit back to DM would anyone please suggest any alternative codes I could use please Any suggestions would be greatly appriciated Thanks Hi Paul I will PM you a code which may work. (this is public I think)
doppy123paul Posted June 15, 2011 Author Posted June 15, 2011 Hi Camullins Thanks alot for that. I'll give it a go Paul
Cyberprog Posted June 15, 2011 Posted June 15, 2011 If you have a look at my Blog, there's some info there on the DM Sprite 2's http://alex.threlfall.me.uk
doppy123paul Posted June 23, 2011 Author Posted June 23, 2011 Hi Thanks for that info. I'll give the hyperlink option a go as the passcode didn't work Thanks again Paul
Cyberprog Posted June 23, 2011 Posted June 23, 2011 It's fairly in-depth, but easy enough to do if you have the skills!
bleeptone Posted August 14, 2013 Posted August 14, 2013 i will PM you a code that should has worked for me several times let me know if it works for you
PeterJames Posted August 14, 2013 Posted August 14, 2013 i will PM you a code that should has worked for me several times let me know if it works for you I think you are a couple of years too late
james.wilson Posted August 14, 2013 Posted August 14, 2013 Could you pm me too please securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
PSE Posted August 14, 2013 Posted August 14, 2013 Same here, got a 16 channel that we can't access, codes been sabotaged Would be good if I can get it back up and running Appreciate if you can send it over,
