Pedders Posted August 14, 2013 Posted August 14, 2013 If you have the newer black fronted DS2, can you not just do a software update Edited cos its in public Pete Bennett Northern CCTV Services T: 0845 838 7383 E: info@northern-cctv.co.uk www.northern-cctv.co.uk
breff Posted August 14, 2013 Posted August 14, 2013 PSE check out a file I uploaded ages ago as you are trade, I think its called DMinfo The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
PSE Posted August 14, 2013 Posted August 14, 2013 PSE check out a file I uploaded ages ago as you are trade, I think its called DMinfo Thanks for that, Will give it a whirl this weekend
breff Posted August 15, 2013 Posted August 15, 2013 Bet the code starts with 6, ends with 6 and is 6 digits long, if so it only works if both engineer and user passwords have been set The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
Map Security Posted September 19, 2013 Posted September 19, 2013 Ive got 6 DM Sprites that we recently removed from service, replacing with Samsung SRD-1670's. some are ADT branded...all are working..... If anybody wants them at a clearence price PM and I'll let you know whats there....
Mavrick_001 Posted September 22, 2013 Posted September 22, 2013 If you enter engineer menu with this, scroll through to codes, turn them off and keep pressing menu until you're out, press and hold menu to go back in and then turn codes back on for your own. No need to upgrade anything, about 250 odd out there. Hopefully you've got the code but if it's not working or you're having fun pm me and I'll sort it. CCTV Intruder Access Control Tony Hughes, Proprietor, TRADE MEMBER
