sixwheeledbeast Posted June 23, 2011 Posted June 23, 2011 hi,the red led flashes when i command ALT+F2 but nothing happens.if i press ALT+F1 the dome turns round it flashes when i move the joy stick it zooms in/out and pans left/right the auto and manual focus works and the iris auto or manual works.there is no reason it is set to address 5. i will try address 1 and all switches on but i am sure i have done before. i will try it now and see what happens.thanks Only the address switches to "all on" not the VCL setting switches leave them as they are. What about keyboard settings??
shifty 1 Posted June 23, 2011 Author Posted June 23, 2011 Only the address switches to "all on" not the VCL setting switches leave them as they are. What about keyboard settings?? ok i have set the address switches to all on and the protocol is still at vcl all off now i select camera 1 but still the same still no camera menu.the keyboard is set all domes on dome 1 thanks
sixwheeledbeast Posted June 23, 2011 Posted June 23, 2011 the keyboard is set all domes on dome 1. Eh? Have you programmed the keyboard to do VCL???
shifty 1 Posted June 23, 2011 Author Posted June 23, 2011 Eh? Have you programmed the keyboard to do VCL??? when you say program the keyboard to vcl how do i do that thanks
sixwheeledbeast Posted June 23, 2011 Posted June 23, 2011 when you say program the keyboard to vcl how do i do that thanks Have you changed any thing on the keyboard at all? How many domes are you going to use on it and what types?
shifty 1 Posted June 23, 2011 Author Posted June 23, 2011 Have you changed any thing on the keyboard at all? How many domes are you going to use on it and what types? well i have my jvc dome assigned to domes 2 and that works fine menue and so on, and all other domes vcl to dome 1 on the keyboard thats what it says in the instructions.thanks
shifty 1 Posted June 23, 2011 Author Posted June 23, 2011 well i have my jvc dome assigned to domes 2 and that works fine menue and so on, and all other domes vcl to dome 1 on the keyboard thats what it says in the instructions.thanks hi i only have the 2 domes connected.regards stan.
sixwheeledbeast Posted June 23, 2011 Posted June 23, 2011 Right then... the Vi-K keyboard is capable of 20 odd different protocol types and can have a different protocol type on each Domes-1 and Domes-2. Sounds like you've just plugged in and it worked (or didn't). Here's the instuctions for programming the keyboard correctly for your system (domes). >>Setting Domes-1 to VCL Hold Alt and press CONFIG "PSd" Press 1, 2, 3, 4, 5, 6. "456" Press OK *"C1.1"* Press DOME Key Press BACK Key Type 0, 5. Hold Alt and press CONFIG "Sto" ---- >>Setting Domes-2 to JVC Hold Alt and press CONFIG "PSd" Press 1, 2, 3, 4, 5, 6. "456" Press OK *"C1.1"* Press DOME Key Press OK Key Type 0, 2. Hold Alt and press CONFIG "Sto" ---- >>Setting Domes-1 and Domes-2 to Camera Channels. Hold Alt and press CONFIG "PSd" Press 1, 2, 3, 4, 5, 6. "456" Press OK *"C1.1"* Press UNIT then press 1 Press Camera press 1 "C1.1", Press Back. Press Camera press 2 "C2.1", Press OK. Hold Alt and press CONFIG "Sto" ---- Set your VCL to Address 1 (terminated) Set your JVC to address 2 (terminated) Connect VCL to Domes-1 Connect JVC to Domes-2 Test and let me know how it goes.
shifty 1 Posted June 24, 2011 Author Posted June 24, 2011 Right then... the Vi-K keyboard is capable of 20 odd different protocol types and can have a different protocol type on each Domes-1 and Domes-2. Sounds like you've just plugged in and it worked (or didn't). Here's the instuctions for programming the keyboard correctly for your system (domes). >>Setting Domes-1 to VCL Hold Alt and press CONFIG "PSd" Press 1, 2, 3, 4, 5, 6. "456" Press OK *"C1.1"* Press DOME Key Press BACK Key Type 0, 5. Hold Alt and press CONFIG "Sto" ---- >>Setting Domes-2 to JVC Hold Alt and press CONFIG "PSd" Press 1, 2, 3, 4, 5, 6. "456" Press OK *"C1.1"* Press DOME Key Press OK Key Type 0, 2. Hold Alt and press CONFIG "Sto" ---- >>Setting Domes-1 and Domes-2 to Camera Channels. Hold Alt and press CONFIG "PSd" Press 1, 2, 3, 4, 5, 6. "456" Press OK *"C1.1"* Press UNIT then press 1 Press Camera press 1 "C1.1", Press Back. Press Camera press 2 "C2.1", Press OK. Hold Alt and press CONFIG "Sto" ---- Set your VCL to Address 1 (terminated) Set your JVC to address 2 (terminated) Connect VCL to Domes-1 Connect JVC to Domes-2 Test and let me know how it goes. hello,thats how i set it up like you have just said but still no joy. all works but no camera menu.ive tried it loads of times but the out come is still the same thanks for your reply.we will get there in the end, thanks regards stan.
breff Posted June 24, 2011 Posted June 24, 2011 Try high numbered presets, I know for instance that the KD6 dome uses preset 98 to toggle between col, col/mono and mono. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
