Shieldsec Posted June 15, 2011 Posted June 15, 2011 Risco have upgraded their high end panel with resettable fuses. I have just installed the Gardtec 601, and as there no charge voltage comeing from battery connection on the board, causing fault (charge volts low), I assume the fuse needs to be reset, but I dont know how to reset the fuse, does anybody know? Sam
MrHappy Posted June 15, 2011 Posted June 15, 2011 a resetable fuse resets its self well the load is removed & the "fuse" is cool enough Mr Veritas God
Shieldsec Posted June 15, 2011 Author Posted June 15, 2011 Thanks Mr Happy, thats what I thought but it didnt reset (still no voltage from bat charge terminals) must be a duff board.. Sam
Monty Posted June 15, 2011 Posted June 15, 2011 could be a new smart charger like the coopers 9853 only has an out put when load is connected you can some times get a reading if you get the clips on as soon as you disconnect the batt ? not used the panel you have posted on but tec support should be able to tell you www.AllanMoncrieffAlarms.com
Shieldsec Posted June 15, 2011 Author Posted June 15, 2011 could be a new smart charger like the coopers 9853 only has an out put when load is connected you can some times get a reading if you get the clips on as soon as you disconnect the batt ? not used the panel you have posted on but tec support should be able to tell you Thanks Monty Yep, ill have to call Risco in the morning. These problems always come when you're about to finish up and get paid!
