Cuchullian Posted June 18, 2011 Posted June 18, 2011 Hi , I am changing the keypad on a veritas alarm as the keypad is worn through and the no.4 no longer works. Spoke to veritas and they said keypads are universal , but upon reconnections, bell box goes into tamper mode and keypad is unresponsive. Any thoughts as to what the problem is ? ,
Monty Posted June 18, 2011 Posted June 18, 2011 keypad universal ?? we don't use the Veritas panel as a norm but have worked on a few and would find it hard to believe that any key pad would work best look for the panel range that you have eg veritas 8 and find key pad that is spec'd for that panel led/LCD possibly the ment all keypads in the veritas range will work standard /led/LCD ? www.AllanMoncrieffAlarms.com
breff Posted June 18, 2011 Posted June 18, 2011 Check the keypad address is identical to the old one The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not)
Cuchullian Posted June 18, 2011 Author Posted June 18, 2011 keypad universal ?? we don't use the Veritas panel as a norm but have worked on a few and would find it hard to believe that any key pad would work best look for the panel range that you have eg veritas 8 and find key pad that is spec'd for that panel led/LCD possibly the ment all keypads in the veritas range will work standard /led/LCD ? Hi , yes it is a veritas 8 and I asked for a seies 8 keypad and thats when they informed me they were all compatible, but i think i'll go back and check again as i wasn't convinced first time.. Check the keypad address is identical to the old one i will go back and talk to technical. .
sixwheeledbeast Posted June 18, 2011 Posted June 18, 2011 Hi , yes it is a veritas 8 and I asked for a seies 8 keypad and thats when they informed me they were all compatible, but i think i'll go back and check again as i wasn't convinced first time.. i will go back and talk to technical. . A Veritas should have a Veritas K series keypad. They should be compatible with the two versions of Veritas (pre-2000/post-2000) The address switches are located on the side of PCB Is it one of these? This thread is worth a read.
