sixwheeledbeast Posted August 20, 2011 Posted August 20, 2011 Recommended 16 Ohm (minimum load 8 Ohm) on Texecom. No idea on the wattage, but would normally use 8W 16 Ohm speakers. If you need something louder you can use a sounder triggered from a switched output. The output can be programmed as Alarm 36 - Chime Mimic or Alarm 50 - Speaker Mimic. Also a Poly Cab P24 will have a small speaker fitted inside. I wouldn't bother with it if your fitting a seperate one.
faugaballa Posted August 22, 2011 Author Posted August 22, 2011 Thanks Chaps, Just wondered what audio power u cud expect from the 24's 'Spk' outputs directly - I'd assume probably much less than 20 watts. I'll know - (and share this knowledge with u!) when it's up & running...
