Guest Grizzwold Posted July 20, 2003 Posted July 20, 2003 Help I have an ADE Optima Compact (6 Zone) alarm which I installed and maintain myself, whilst recently doing some building and decorating work I changed some settings and configurations to prevent accidental setting off of the alarm. I have now finishe the building work and have finished rewireing the panel back to it's correct state, however in the upheaval I have lost both my engineering and user manuals. Can anyone help with a copy of these manuals so that I can reset my alarm to normal operation? Thanks.
Guest kenny james Posted August 31, 2003 Posted August 31, 2003 your best bet will be to power the panel down and reset to factory conditions this way you will know your engineer code will be 9999 and your customer code will be 0123. if you send a request to dave to send you a pdf manual i'm sure he will do it for you. otherwise let us know and i will tell you the procedure for doing the above.
Service Engineer Posted August 31, 2003 Posted August 31, 2003 Just sent you the manuals, hadnt got the compact user guide though so sent the one for the accenta 8. ........................................................ Dave Partridge (Romec Service Engineer)
Service Engineer Posted August 31, 2003 Posted August 31, 2003 Looks like your email address hasnt been activated....? Hi. This is the qmail-send program at mail.valuehost.co.uk.I'm afraid I wasn't able to deliver your message to the following addresses. This is a permanent error; I've given up. Sorry it didn't work out. 165.212.*.** does not like recipient. Remote host said: 550 <grizzwold@********.net>... User account not activated Giving up on 165.212.*.**. Please PM me with a valid email address if you want the manuals. Due to this post (but not only) I have activated the New User registration email validation option. Basically this means you can no longer become a member of this forum without a valid email address. ........................................................ Dave Partridge (Romec Service Engineer)
