ade52uk Posted June 25, 2011 Posted June 25, 2011 Hi, hope somebody can help !! I have a Maxcom Keyboard and Maxcom Gold switcher, but no interconnect cable. The Maxcom keyboard is a 4V unit HKJMMTP-EU which I believe is an RS485 unit. On the rear of the unit there is a RJ11 power and an RJ45 Control connector. The Maxcom switch is a 16/2 unit HMAX162-EU. They are both black in colour. On the panel of this unit there is two RJ45 Keyboard connectors and also a RJ45 TP (for telemetry I guess) 12v RJ11 power and serial ports marked PC and RS232 CTRL. Does anybody know the pinout for the keyboard ? As in how to connect the two units ? Do you connect the Control to the KYBD1 ? From the manual (HMMI-001-01-00.pdf) I have for the Maxcom Gold switch states The keyboard connectors are ‘RJ’ Type Connectors. A cable with 8-pin RJ45-type plugs on both ends is provided for connection between a keyboard and the MaxCom Gold The pin-outs for KBD1 and KBD2 are as follows: Pin 1 Data+ White/Orange Pin 2 Data – Orange Pin 3 Ground White/Green Pins 4 – 8 Not used Thanks in advance, Adrian. HMMI-001-01-00.pdfFetching info... Honeywell_MaxComGold_DS_UK.pdfFetching info...
