nigelbt Posted July 21, 2011 Posted July 21, 2011 Hi, i have a galaxy 16 plus that i am trying to set up a temporary restricted user access code for someone, i have tried to change by option 4 "codes" select user, then when i press enter the code optoin does not appear to program, it just enables access, i am trying this from the engineers access code, is it possible to do this from there or am i missing something else, the only other thing i can think may be the problem is i need to access from managers option, unfortunately as a man i just assumed i would remember the code but i cannot, if this is the way to add new codes can anyone tell me if it is possible to reset the managers code,i have tried browsing forums but cant find anything, thanks, Nigel.
nigelbt Posted July 22, 2011 Author Posted July 22, 2011 Thanks buddy. is there any way to reset the manager code without having to reset everything, ta.
james.wilson Posted August 11, 2011 Posted August 11, 2011 if you have engineer access then you can reset the managers code to default from the parameters menu securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount.
